Long story short then background...
When I try and start my Ford 641 it sounds like the starter is just spinning with no engine turn over. Identical to this:
https://youtu.be/Rgn6zPn6ZJY
Background:
A few months ago I purchased this tractor. It started right up but ran a little rough. I did a tune up (plugs, wires, ignition coil, new fluids and filter). After tune up she fired right up and I ran her a little. However after a week I noticed gas in the oil.
So... I rebuilt the carb and she fired right up (I also know now not to use to much choke). I needed to change the oil again due to gas in the oik and it had a minor oil pan leak so i figured I would replace the oil pan gasket. After waiting 2 weeks for the part to get in and finding the time today I did it. Because she had sat for so long I didn't want to fire her up to move before changing the gasket and recycle the gas oil.
Put her in neutral and towed her 40 feet so I could work on her. Replaced gasket just fine. Went to start her up and the YouTube video is what it sounds like... Like I said prior to this no issues starting.... Any ideas?
Background:
