TractorLinks.com
Show Parts for Model:
Removing stuck rocker pin
TinCan
01-12-2018 17:22:49
Does anyone have any easy ways to remove a frozen rocker pin. My rocker is broke, and the eyelets where the pin goes through are wore out bad.
I have heated it, and hammered on it, but it won't budge. Now I need a new pin also.
Pat
TinCan
01-22-2018 17:06:40
 Re: Removing stuck rocker pin in reply to TinCan, 01-12-2018 17:22:49
Cast steel, should be no problem welding. I weld cast steel often. I weld up custom steering sectors, steering arms, and shorting I beam axles for hot rods, and other cast steel. Not cast iron. I have never had a weld fail. I have been welding since about '70
corvetttteguy had problem, because he most likely bought welding rods for cast iron, not steel rods. I tig, mig, stick, and gas weld.
The only problem I'm going to run into fixing my rocker, is I have to make, and weld in sleeves. Or weld up, and resize most the bores. I don't know if I want to go through all that. But then again, it's free to fix, and cost money to buy a different one.
Pat
Dollar Bill
01-22-2018 07:42:37
The rocker is not an item that I would attempt to stick weld an I am a certified welder. Maybe TIG but for your safety, I recommend finding a replacement rocker.
corvetttteguy
01-22-2018 03:56:30
I bought a $24 pack of cast weld rods
from TSC and my S-I-L tried
welding the TSC collar. WOULD not
stick to collar. Finally had good
luck welding with standard steel rods.
TinCan
01-21-2018 16:44:55
Finally warm enough to work outside again. I drilled a 1/8" hole into the back of the rear end housing into the rocker pin today. I put some PBBlaster into the hole, and on the sides, again. I then came back 20-30 minutes later, I hit it with my small maul, and it moved. I got it out. Now I have to rebuild the rocker some how. Since it's cast steel. I can weld on it. I'll see how it goes.
Thanks, Pat
TinCan
01-13-2018 16:50:45
RBnSC,
I tried to send you a PM, but say's it's disabled.
Send me a e-mail about it, and how much.
My e-mail is: a392hemi@yahoo.com
Thanks, Pat
showcrop
01-13-2018 16:20:30
Diamond blades aren't that much money.
jchewie
01-13-2018 14:25:05
Mine was stuck bad. Wheel removal not an option. Tried cutting with a sawzall, maybe the pin was hardened, it didn't work. Tried hammering, tried pneumatic hammer, nothing worked. I used Kroil, but don't have acetylene.
What finally did work was clamping a 6 ton bottle jack and a piece of round stock on one side of the pin, a pipe coupling over the other side of the pin, and heavy angle iron welded square around all of that for the bottle jack to react on. Came right out.
riveroadrat
01-13-2018 12:17:23
Quoting Removed, click Modern View to see Someone mentioned using heat and parrafin on something that was stuck.
Dean
01-13-2018 08:12:46
You could whiz wheel the rocker off before driving out the pin.
I remove the wheels so that I can wail on it from both sides with a 4+ Lb. hammer and piece of hard brass. Don't get carried away with a sledge hammer or you might break the differential casting.
They can be stubborn but they will come out.
Dean
corvetttteguy
01-13-2018 06:58:00
Some pics
Donor 641 after removal
821 rear and reclaimed pin
Welded TSC COLLAR
RBnSC
01-13-2018 04:37:57
Bolt your motor to this.
corvetttteguy
01-13-2018 04:03:39
Had the same problem on a 641 that was left outside
for 30+ years (uncovered). My top link socket was also
broken off like yours.
To speed up the process I drilled a small (1/8 hole)
in the middle of the rear casting to allow P blast
to get in and work. It took 2 weeks of constant spray
of lubricant before I noticed that I could beat the
pin a little. At that point I hit it back and forth till
it came out.
Pin was completely salvageable in my 821 rear end.
And son in law welded TSC collar in place of the
broken top rings. I didn't want to spend $100
for a new top link rocker.
I figure I can add a grease fitting into the hole for
future lubrication.
showcrop
01-13-2018 03:55:19
I just cut it with a recip saw.
Dollar Bill
01-13-2018 01:42:31
The only easy way that I'm aware of is to take it to dealer - They do not like to come apart.
Kroil, heat & beat is the most common method of removal.
A stout air hammer may help.
obwan
01-12-2018 21:21:28
Some ideas
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=nboard&th=484942
