TractorLinks.com
Order Ford 841 Parts Online
841 hesitating
clam digger
01-12-2018 12:41:05
My 841 hesitates when I throttle up. I replaced the plugs with AL 437 new cap, rotor points and condenser and wires coil. Rebuilt the carburetor and went through it a few times checking all the ports and float. The float does have a small dent but no holes. Compression is good Dry 115 120 130 130 Wet 120 125 140 145 . The valve sound a little noises . I was just out in the barn and found the timing to be set at 8 BTDC and there was a white mark at 8 so I retimed it to 4. Sounds great starts right up but still coughs when I throttle up. I also disconnected the throttle and governor linkage and moved the throttle butterfly by hand and the governor does move. I havenít had a chance to take it out and see if stalls under load pouring rain and I am sick as a dog. . It came with a new Zenith on the tractor but i never ran it with it on to many leaks. It also came with the original MS so I rebuilt it next step is to switch carburetors. I will take all the help I can get. Thanks in advance
ernied
01-14-2018 18:49:04
 Re: 841 hesitating in reply to clam digger, 01-12-2018 12:41:05
Try 1/2 choke when you throttle up. If symptom is absent adjust idle and main jet mixtures on the carb. I did see one where only 2 cylinders were firing; every other was fouled out. Obviously low power; but the exhaust note was even and the governor made up the adjustment.
cheif
01-13-2018 07:59:07
I had the same trouble with my 850. Found a cracked intake manifold. Tough bugger to isolate!!
clam digger
01-13-2018 09:32:04
 Re: 841 hesitating in reply to cheif, 01-13-2018 07:59:07
Just got in from playing with it. First time outside in a few days. I took it out for a little ride and it's a little better but still dies under load. I though about checking for leaks in the intake I will used my torch with just the gas on and see if it revs up then take out distributor and see how the advance is but I couldn't stay out to long coughing too much
showcrop
01-13-2018 05:16:41
That's me. A sickness.
showcrop
01-13-2018 03:53:03
Clam digger, I can see that your 841 is giving you a lot of trouble. Before it completely ruins your quality of life, why don't you let me take it off your hands for say, 10% over what you paid for it?
clam digger
01-13-2018 04:27:27
 Re: 841 hesitating in reply to showcrop, 01-13-2018 03:53:03
That's a good suggestion and I will put you on the list. It man versus machine if I throw in the white flag I'll get in touch with you . I've been retired for five months and this beats going to work any day. There is a song by Mark Erelli called The Fix It Man check it out on YouTube that's all I hear when I am in my shop.
Dollar Bill
01-13-2018 02:35:00
Forgot to include a visual to help you confirm firing order:
Dollar Bill
01-13-2018 02:15:21
Back fire is generally due to three things:
(1) Crossfire in cap due to moisture, or wrong firing order.
(2) Lean air/fuel due to inadequate fuel flow, air leak, or improperly adjusted carb.
(3) Points closed up or worn distributor bushings. Be sure to measure point gap on all four lobes.
Failed timing gear can cause similar problems but your compression tested great.
There are quite a few posts regarding run issues with repopped carbs so you may save yourself grief with a professional rebuild of the OEM carb.
clam digger
01-13-2018 03:13:45
 Re: 841 hesitating in reply to Dollar Bill, 01-13-2018 02:15:21
Wireing is all correct . I will check all of the lobes and advance. I been sick all week and read all of the archives . Feeling a little better so I might put the new Zenith carb that came with the tractor on today . Thanks
ron muhlenkamp
01-12-2018 15:08:28
If point gap too wide, will act like having trouble jumping the gap
Dean
01-12-2018 14:55:47
Misfire upon acceleration (fully up to temperature) often signals a lean mixture. Try turning the mixture screw out 1/2 turn or so.
Of course, one should never look to carburetion until one is certain that the ignition is spot on.
Dean
fordfarmer
01-12-2018 14:38:23
Have you checked the distributor advance mechanism? Could be rusty and sticking, or maybe broken springs...
clam digger
01-12-2018 14:47:36
 Re: 841 hesitating in reply to fordfarmer, 01-12-2018 14:38:23
No yet but I will now . I have a NAA can I switch them out to see if the distributor is the problem?
clam digger
01-12-2018 14:50:48
 Re: 841 hesitating in reply to clam digger, 01-12-2018 14:47:36
Never mind I just looked them up can't be switched
