Doug Wi
want to put joystick control for the loader. have read the posts about the 7710 loader install currently going on, but the 6700 is a different set up . Is there a place to get preasure for the valve or should I just use one of the remotes like I have seen done on many tractor /loader setups?
I think you use a power beyond plate on the lift cover under the cover plate. Same place you'd put a remote valve. Would have to check parts book.
