Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Loader recommendations for 7710
MNfarmer
01-10-2018 03:38:49
Thanks everyone for your help and responses to my questions so far! I've narrowed my choices down to these three loaders and wanted to get your thoughts on which would be best. The westendorf ta28 is the most expensive of the three but looks like a well built loader. I like the looks of the allied 595 and it's the cheapest of the three. I've talked to a few people that have allieds and they all like them. Third is a quicke x41, middle of the road on price but looks to be a little lighter built and no front frame. Thanks everyone for your time and your help!
BarnyardEngineering
01-12-2018 07:33:25
 Re: Loader recommendations for 7710 in reply to MNfarmer, 01-10-2018 03:38:49
Take a closer look at the mounting brackets for the Quicke.
I recently saw one on a red tractor, and the mounting brackets joined the front and rear of the tractor together, and acted as the loader frame.
RodInNS
01-10-2018 08:26:53
Go with the Quicke... They're a good solid loader, easy on, easy off. Just make sure that the particular model you're looking at is up to the task of standing in front of that tractor.
Rod
MNfarmer
01-10-2018 09:52:29
 Re: Loader recommendations for 7710 in reply to RodInNS, 01-10-2018 08:26:53
Thanks Rod, the x41 is what they recommended for the 7710 but I haven't been able to find much info online about it. I know from the pictures it's only supported from the rear loader mounts and there's no loader frame that wraps around the front of the tractor. Will the tractor hold up ok to that style?
RodInNS
01-10-2018 09:58:26
 Re: Loader recommendations for 7710 in reply to MNfarmer, 01-10-2018 09:52:29
I think so.. Big thing is to make sure you keep the mounting bolts tight. Having the front wrap around frame that isn't bolted solid is no guarantee that the tractor won't break either. Most Alo's I've seen were mounted on 40 series and newer tractors that do have a bit more meat through the front support.. but the 10 should be fine too. Overall I would have much more confidence in the Alo loader than the Allied. No experience with the Westendorf... but what I see of them looks clumsy compared to the Alo.
Rod
MNfarmer
01-10-2018 13:02:27
 Re: Loader recommendations for 7710 in reply to RodInNS, 01-10-2018 09:58:26
Ok thank you Rod!
Destroked 450
01-10-2018 07:57:51
I have a Allied 495 on a 6610, good loader, a bit heavy for a 2 wd tractor, pain in the a-- to put on or take off, the frame work that stays on the tractor is always in the way when doing any maintaince work.
MNfarmer
01-10-2018 09:53:10
 Re: Loader recommendations for 7710 in reply to Destroked 450, 01-10-2018 07:57:51
Good to know.. thanks!
fordfarmer
01-10-2018 04:04:01
No experience with the Quickie, though they seem to be well respected. My cousin has an Allied 595 on his fwa 7710. Probably getting close to 20 years old now. He's had some trouble with the joystick, but no problems at all with the loader. Only real disadvantage compared to the TA28 would be that it takes 2-3 times as long to put on or take off, and you have to mess around with stands, where the Westendorf uses the frame.
MNfarmer
01-10-2018 09:54:12
 Re: Loader recommendations for 7710 in reply to fordfarmer, 01-10-2018 04:04:01
Thanks Fordfarmer!
