As I re assembled my 3400 gasser today I began to wonder why I couldn't swap out the hard fuel line to the sediment bowl and the shorter hard fuel line to the carb? Couldn't I just find a gas fitting that had a tapered barb on it for the fuel pump and then find a similar bigger fitting for the female at the carb and then run 1/4" RUBBER fuel line with an in line filter in it? Seems someone out there might have done this? Can't imagine what harm it would be. It would certainly make dealing with the carb, intake, fuel pump and everything else in the way a whole lot easier AND less prone to leaks!
any thoughts?
any thoughts?
