801 diesel advice
cowdog
I found an 801 diesel for sale. Same old
story. Ran 4 years ago, now only runs on
ether. Decent tires, select o speed, .
What would you guys look for? Or would you
cut and run like he!/.
Since you can't test the transmission or the hydraulics or the engine bearings or injection pump you have to assume that all will need extensive work. Injection pump $750, engine overhaul DIY $1,000 transmission overhaul $1,500 hydraulics DIY $250. Average value when working properly $3500.
