Danny Prosser
Good morning my friends. I'm working on my tractors this winter fixing them up for spring and got a question. My 640 started making a grinding noise on the right rear and I figured it was something broke. Well I pulled the wheel and drum but everything looks ok. The brakes don't work real well though. When I push the brake pedal down it only spreads the adjusting side of the brake shoes a little even though they are adjusted out tight with the drum on put don't work well. However when I pull up on the pedal they move quite a bit. I noticed that the pedal shaft wobbles in the end that go's into the rear end. Is that where my problem lies? And how would one go about repairing that? I thought about pulling it out and trying to put a bushing or sleeve on it. Anybody ever have this problem and how did you fix it? I'm fixing this one up to keep my sickle mower mounted on for cutting around my pond and ditches and would like the brakes working good. Thanks for any replies or suggestions.
