Rustbucket
I tried using Todays Tractors, but message would not post so I will try here.
Troctor currently will blow a huge bunch of blue gray smoke intermittantly and die if idleing. I traced the problem back to the turbo which would build up a pool of oil in the intake and then suck it in which caused the poor running and then clean up again then on and on. New turbo 1100 dollars, rebuilt 900, 150 core and 50 shipping if core can be rebuilt you get a refund. OK here is the question? Has anyone tried just deleteing the turbo or found a different supplier than New Holland?
