3000 power steering box
corelokt
The tractor I bought has
the steering box snapped
in half above where it
bolts together. What are
my options for repair?
Can the box be brazed?
Should I go with an after
market kit?
Used boxes seem expensive.
As I mentioned before, you don't give us enough info to go on to give you any meaningful advice. We're not mind readers here.
That column bolts together in a couple of places. #12 is the part you usually see broken on these.
Generally though I would say buying a new or used part is the answer. They are a very simple mechanism but are precision enough that cobbling one will only cause early failure somewhere else.
The trouble with buying used is finding someone who will part out their steering column.
It makes the rest of the column unuseable and they are valuable as a unit.
I would buy a new one at the link I provided.
