Hi All I am new to this forum and have bought a ford tractor and need to buy some parts for it(brakes and seals etc.) but I am having trouble trying to find out what model it is exactly. It has 4500 on the side of the hood but I know it is a 3000 series because of the tag #s and that the brakes are drum brakes and not internal that the 4500 has. The problem is I can't find out if its a 3300 or 3400 or 3500 etc. The numbers on the tag under the hood match all the numbers on the tractor. Here are the numbers.
Tractor# C250082
Serial# none
Model# C5011F
Unit# 9J18B
Engine# 9E30B
Trans# 9J2
Rear Axle# 9H08B
Hyd# None
Hyp Ln None
So from these numbers I can see the it was built in 1969 Sept 18th on the day shift.
It is a 3000 Industrial Diesel with no pto and a 44T_C power reversing trans.
But like I said I need the exact model # to order parts. I have talked to a few dealers and they can't tell me what it is either. So any help would be greatly appreciated. Thanks in advance Ken
Tractor# C250082
Serial# none
Model# C5011F
Unit# 9J18B
Engine# 9E30B
Trans# 9J2
Rear Axle# 9H08B
Hyd# None
Hyp Ln None
