I have a 861 ford. I recently cleaned all the crap out of the carb and installed a new carb kit. I got the tractor running pretty good. Now
its wanting to run ruff and throttle response is not very good. I am also heaving charging issues. If battery gets low enough will it cause
running issues? It still has the generator. Are there any kits out there to rebuild these generators or should i switch to a 12 volt system?
Thank you
Thank you
