chowchewey
New User
So I was out plowing snow with my 1978 1700 2 cyl diesel when suddenly coolant started blowing out the rear block freeze plug and started running a little warm. Headed back to the barn - and sure nuff steam and coolant was pouring out the rear plug that was slightly unseated to the right side. so now for the questions:
1) what caused the plug to become unseated? would being hot do that on its own? Note - the coolant is very fresh and full and a good green color. It is stored in a barn and i would guarantee the coolant in the block did not freeze even partially.
2) Normally i can plow snow and the block is just warm - this time it was hot. the top radiator hose was pretty warm so that tells me the tstat is opening. the bottom hose was cooler but warmer than the air outside. The best i can tell the water is circulating but couldn't spend much time on it yet to know for sure.
3) as far as repairing the plug - buy new or re-use existing? also any ideas on the proper way to re-seat it?
4) OK to continue to plow if i make sure it doesn't overheat?
Thanks for any info you can provide - i enjoy reading the posts - the knowledge shared is really incredible.
