More 641 questions
jr1983
Will a 641 pull a two bottom with turf tires on the back? I just want to plow my garden. Have a chance at a two bottom but also have a chance at a set of turf tires that are much better than the tires on it. I do have a set of chains if need be. No ballast of any kind. Its primary purpose will be a finish mower hence the additional desire for the turf tires. I still have a lot work to do on it but I have the chance at a trade deal for the plow and a spring tooth cultivator.
(quoted from post at 05:45:22 12/22/17) Will a 641 pull a two bottom with turf tires on the back? I just want to plow my garden. Have a chance at a two bottom but also have a chance at a set of turf tires that are much better than the tires on it. I do have a set of chains if need be. No ballast of any kind. Its primary purpose will be a finish mower hence the additional desire for the turf tires. I still have a lot work to do on it but I have the chance at a trade deal for the plow and a spring tooth cultivator.
Sure! No problem! It will take a LOT of added weight however. I would keep waiting for a better set of R-1s to show up. There are 28 inch R-1s on CL pretty much all the time here.
Worst comes to worst I can get a set of combine tires and wheels to put on when the garden needs plowed. I want the turf tires for the rest of its duty's. I'm thinking it should be a three bottom unit so in a small area a two would be OK. Does anyone know if I'm right?
