1956 Ford 600 hydraulic pump noise
Carlk0283
New User
Anybody have any idea why my hydraulic pump
would be making a grinding noise? Had the engine
rebuilt and the pump wasn?t making any noise. Put
I‎t back together and now my pump is making a
grinding noise. I?ve tried to upload a video but I‎t
won?t let me. If anyone is familiar with these pumps,
if you?ll email me at [email protected] I?ll send
you the video.
Not sure what you mean by "grinding" noise.
Did you set the drive gear backlash when you reinstalled the pump?
Dean
Can i send you a video i took Dean? I watched a youtube video of how to install and bleed the air out. I‎t didn?t mention anything about backlash.
Did you tighten the camshaft pump drive gear? I would remove pump and check for metal debris. If you have worn crank and camshaft gears they will make noise at the pump when you are lifting something.
(quoted from post at 14:59:29 12/19/17) Did you tighten the camshaft pump drive gear? I would remove pump and check for metal debris. If you have worn crank and camshaft gears they will make noise at the pump when you are lifting something.
I forgot to ask, who rebuilt the motor? Was the camshaft thrust plate checked? I have seen them broken before. If you pull the pump, pry a big screwdriver against the bolts and see if you can lift the rear camshaft driving gear any. I have an engine that either has a worn camshaft or camshaft bore or both. i could raise the gear 1/8" - 1/4". I quit driving it.
I took the pump off and the camshaft gear etc has
no slack what so ever and there was no metal
shavings or anything that looked abnormal. Can i
send you a video of it running?
