serial bb25789 i think 87 series II correct?
i have a manual on the way but just wondering about the following.
1. does it have open or closed circuit hyrdaulics? i have read both
2. what would be needed to add a 2nd remote?
3. should my tractor have the injector pump that needs the oil changed? if so anyone have a pic of the filler and drain?
4. it has the engine mounted hydraulic pump, how many gpm is that rated at?
5. what type coolant/additives should i be using? i use rotella elc antifreeze in my other tractos will that be a good choice for the ford as well?
thanks for all the help.
