I went and got the 641 the fil gave us. Now that I've had a
chance to evaluate it i have a few questions. the whole
electrical is gone drained a large quantity of water out of the
trans pulled the plug in the rear end got nothing. The main
transmission housing is cracked badly and the rad has a hole in
it. So before I go any further in my plans do the trans and read
end oil run together? Also what do I do with the trans? I'm
thinking a replacement must by found. What tractors use this
transmission? There a couple transaxles at the scrap yard that
look right but with only rear end and trans is there a way to
tell if I way getting the right one? Also if I happen to find a
five speed will it bolt in? Thanks I'm sure I will have lots
more questions as this goes. P.s. as I said in a previous post
the wife's grandma bought this new. She farmed quite a bit of
ground back then. I have the chance to save it for the next
generation so I'm going to fix it weather its worth it or not.
