641 hydraulics
fran213
I bought a 641 tractor.It looks like it has hydraulic ports under the seat with no fittings on them,only pipe plugs.How are these hydraulics operated ?
If one lever probably two plugs. You can run hoses to operate a piston for toplink or maybe a snowplow. Some guys will plug them up if not being used. Just. As easy to put a quick disconnect of them but it does cost a little more cash
Kirk
(quoted from post at 11:49:16 12/15/17) Is there a lever, besides the 3pt lever?
Of course there's a lever, the draft/position control lever. The question is, "Are there two levers?"
