toocheaptosmoke
New User
Hi Guys,
Almost a year ago I bought a '66 4000 gasser from an auction with a hole in the block. Was my first decent sized tractor, by the summer we had it back in action. Probably would have been better off as a parts tractor, but it's back to live another day. Here's some of the old threads,
http://forums.yesterdaystractors.com/viewtopic.php?t=1302711
http://forums.yesterdaystractors.com/viewtopic.php?t=1303988
Ended up doing things the hard way and I bored out the new used block .020" by hand. :shock: Lost a good 2 weeks of my life doing that, but I saved a good bit of coin...
https://youtu.be/9I8J57MeDK8
When I got it,
Got everything back together and most of the bugs worked out, then was able to borrow a friend's 6' brush hog and do a bit of work putting a good load on the engine to help seat the rings in. The original holley carb is still working alright, but have not been able to get rid of the initial bog when you open the throttle. Runs well other than that.
(my dad stole it for a spin )
Next thing I want to do is find a loader for it, from what I can find the 772 is the direct fit. I know others may also, but I would like to get something with at least as much capacity as the 772. Roughly how much should these go for used?
I found what looks like a 4000SU gasser with a loader for $2200 with a blown head gasket, but it looks like the front cowling is part of the loader frame support. Is that the only difference on the SU loader? Could possibly swap everything over.
When I got it,
