66ford3000
OK I had a leak intially in the upper
seal and I used a quick sleeve kit
online and it was a pretty poor looking
sleeve and needless to say the sleeve
came apart and started leaking within
like 20 mind ,the top hat part came off,
so seeing I have to take it back apart I
ordered a new adapter plate that came
with a new needle bearing and seals,is
there any tricks I need to know or is it
pretty cut and dry when I take the
hydraulic portion off?wasn't sure if it
would have plungers or anything fall out
and how tight should the nut be for the
bearing ? I'm going to use a longer
repair sleeve to hopefully avoid this
problem again the shafts didn't look
terrible by the eye,thanks!
