Just picked up a 4000 parts tractor with an SOS trans to use for parts on my 4500 and I'm curious what of the rear axle is the same. I know the ratio is different, but it looks like that is in the ring & pinion and the planetaries are the same - is this correct?
Assuming this is the case, can I swap the entire axle planetary/brake/outer housing assembly? The brakes on the 4500 are pretty well shot and it seems like that might be easier than pulling the 4500 ones off and then stripping them far enough to change brake pads. What I'm unclear on though is if the ring gear comes out with the outer housings, and if it does will I have to adjust backlash and whatnot? Will this be more or less of a pain than just replacing brake discs? I think I've got a leaky axle seal but otherwise the 4500 axles seem ok. Wouldn't surprise me if 4000 bearings and such are in better shape than the 4500 too - 4500 looks to be well beat on in it's life.
Different tangent - is there any difference between the 3000 & 4000 SOS trans other than the d planetary on the 3000? I've got a 3500 with SOS and I'd like to know if the 4000 trans has enough in common to be worth storing for spare parts down the road. The 4000 has a stripped input shaft and apparently a pump front seal leak but was otherwise apparently functional.
Thanks.
Thanks.
