fran213
I have a 641 tractor that creeps a bit in neutral while letting the clutch out.Will a clutch adjustment fix this ?Any ideas
Cold oil or heavy oil in transmission tends to hydraulically drive the unit. clutch adjustment has nothing to do with it.
Mine 960 did that too. As Larry said, I changed the oil and it quit.
I used UTF that meets Ford spec M2C134D. Containers are labeled.
You can buy it at Walmart, TSC, NAPA, etc.
Mine tries a little when its cold because of thick oil in tranny. After it warms up for a minute things are fine. Thick oil is to slow down leaks.
