Had problem charging. Had generator checked at shop...was good. Replaced regulator. I thought it was fine. Battery seemed to be charging. Nothing felt like it was getting hot. About 3 months later
noticed the the wire on the back of the generator had got hot enough to burn off the insulation around the connector. Upon further searching found that the regulator had got so hot that the plastic housing
was melted and the wiring connect to the regulator had got hot enough to melt a small amount. Any clues what happen/what is wrong??? Shop said the generator is fried. Looks like it needs new generator,
regulator and wiring harness now. Thanks.
