Can you swap out a CAV pump with a sims pump i am swapping out engines and i need the simms pump on here so i can put the throttle linkage etc back on and i can change out the lines also. Thanks
UD, you are correct, the front cover is the same, it's the plate that the pump mounts to between the block and timing cover that is different. The drive gears are also different.
