What do these weights fit?
Ultradog MN
Location
Twin Cities
These are at an upcoming auction.
I'm wondering if they would fit my 38" centers. All I have to go on is they are supposed to be Ford weights and these photos.
Any thoughts?
I'd almost bet the part number is cast into the other side. Have contact info to see if they'll check for you?
If they won't fit your 4200, but are the same as the ones on my TW, you know where you could get rid of them, as long as they're cheap. :)
Three holes give you 120 deg on the weights, two holes give you 120 deg on the wheel center,
so they'll mount with 3 bolts to the rim, if the bolt circle diameter is compatible.
It seems that the round holes showing must have square head bolt captures on the opposite side.
Then I think you could keep bolting more weights to each other.
