Ford 3000 axle pivot spacer
robertfb
Hi all, i have my 3000 front end all torn apart (new kingpin bushings/thrust bearings, pivot bolt and bushing) The issue is I can't find a source for the spacer, PN C5NN3403A.
None of the parts places who gets it from A&I has it in stock (they are out too). My local CNH dealer has it for $80!!!! which is too much to pay for something that I could make in 15 minutes wit a bit of heavy tubing and a lathe, if I had one.
I may just stick with my worn original and live with the slop, unless someone has a better used one (or a lathe I can borrow!).
