When I flip leaver to engage pto it either takes a
minute or so at idle or have to rev up rpm for it to
engage. New hydro pump. Any suggestions.
I think the next thing I'd do is run the engine with the 3-point lift cover off (you'll need to fashion up a diverter pipe for the main hydraulic pump flow). I'd also lower the oil level enough that you can see the various pressure lines for the PTO clutch and valve.
