Picked up a 78 model this past weekend, haven't got the manuals yet but working a few items anyway. Replaced the filter to injector line as it had an ill filling hose spliced onto the line and was leaking. Leaks also from the plate behind the inlet fitting and the bolt on the bottom of the pump. Anything I need to know other than replacing the gasket and O-ring? Top cover gasket has already been changed by a PO. Gasket kit is on the way. Also have a leak from the bottom of the fuel filter housing. What is supposed to be there? Is it a bolt or a drain fitting? What is there looks like a fitting with a line crimped off. I can't find any reference off the New Holland parts diagrams.
Thanks,
Thanks,
