NAA lift pump upgrade
1954NAA
New User
I saw a photo where someone had upfitted a different, more modern pump to the NAA. Can someone direct me to them?
Well... theres the older vane pumps with and the ever-so-slightly newer wobble plate pumps that replaced the vane pumps. I have never seen a vane pump on an NAA or a hundred series tractor. The wobble plate pumps are very
easy to overhaul and kits are not expensive.
There are front and PTO mounted pumps but I dont think thats what you are asking.
This pump from a Jacobson G-10 mower tractor will fit as the Jacobson uses basically the same engine. The engine will fit the NAA also as I put one in my Jubilee.
(quoted from post at 11:56:50 11/29/17) This is who you are looking for.
Mark
TOH
Didnt you machine the gear housing find it an aftermarket pump? I have the oic, but can't get it to load
(quoted from post at 15:10:07 11/29/17)
Mark
TOH
I think this is what you are looking for. It is a retrofit of a common off the shelf gear pump that replaces the proprietary and much more expensive Ford piston pump. Works great - industry standard and inexpensive gear pump replacement for the OEM pump. Call or email me.
TOH
301.655.0631
[email protected]
