jimf in mo
I have seen a lot of post on steering gear lubricant here and I believe the majority say grease, the pourable kind. I have recently reconditioned my power steering gear (64 4000 4 cyl.) Complete disassemble all new seals O-rings etc. and I'm ready to see if I did a good job. Looking at my IT FO20 it says 1.5 lbs. for the steering gear housing which make it look like grease The solid kind in a tube. I also thought I saw a post that ford change the spec form oil to grease in the early '60. If it is grease what type. Also question on PS fluid I see a lot of opinions on that. I've tried to see what meets the M2C41 spec but haven't been able to figure that one out either. input will be appreciated. Thanks in advance
