AICO Diverter valve
does it have a big 5/8 or so inverted hex plug on the back of the spool shaft area? I have one almost exactly built the same
way, different manufacturer. but just some orings and a spool and the machined casting and one ball detent.
(quoted from post at 17:09:01 11/27/17) does it have a big 5/8 or so inverted hex plug on the back of the spool shaft area? I have one almost exactly built the same
It sure does and I had to go buy a tool to get it loose. :)
Do you use that valve to operate one of your one arm loaders? That is my plan for mine.
