PatsTractor
Hi, I have a 57 Ford 640 134 ci engine..no fuel at the plugs..
Carb is new and assuming I have good compression does anyone know why I would have no fuel at the plugs?
Tractor ran fine just this month but no I have a no start situation.
Carb is getting tons of fuel.. it leaks out the intake exit at the carb if I leave the choke on too long while spinning it over.
so plenty of fuel at the carb but nothing at the cylinders/plugs
plugs are dry as a turkey bone that's been sitting around for a week.
How does this updraft system function?
Could a bad intake manifold gasket cause fuel from being distributed to the cylinders/plugs?
Going to the manual to read up on this stuff but it does have me stumped a bit at the moment.
Anyone ever had this issue before and found a solution?
Thanks in advance.
Thanks in advance.
