As I've discussed before, my pump strainer was heavily blocked and even after splitting the tractor and cleaning it the best I could, the hydraulics were still slow and jerky. I was advised that the remote filter from a 4600 would fit and so I sourced and bought the necessary parts.
After a lot of hassle and unbolting stuff (not least the top cover which wouldn't come off without a fight) I destroyed the old filter in removing it. Thinking the new assembly would just go straight in... it doesn't. The hole in the side of the gearbox casting is slightly too small (the paper gasket on the remote assembly has a cutout in it to enable it to fit but the cutouts in the casting are a different shape and smaller). I'm now left with a tractor with no rear hydraulics. Short of running it unfiltered (if I can make up a suitable feed pipe to the pump) or grinding a recess into the casting, I'm stumped and depressed.
