johnofnewhaven
I have had the 3000 for about 6 weeks now
and put about 20 hours on it. I removed the
spark plugs to check. 1 and 2 looked fine.
Number 3 had a small amount of white crud
on it (Crud for a lack of better term). I
put a camera scope into number 3 cylinder
and see a small amount of white crud on top
of the piston. It is on just one side of
the top of the piston. I would say about 1
inch by 2 1/2 patch of it. Water leak into
the cylinder? Bad head gasket? Could it be
a bad intake manifold gasket? Thank you for
your advice in advance!
