TractorLinks.com
Order Ford 601 Parts Online
Transplant hydraulics from 601 to 821 ???
corvetttteguy
11-14-2017 09:48:43
I am transplanting the hydraulics from a 601
to my 821 (only has PTO). I have the hydraulics lid
on a motor stand and am ready to install
it on my 821.
First, I noticed a ?plug?/valve? near the
bottom of the 601 that is not on my 821.
Should I try to remove it?
I plan on taking the next steps, let me know if I'm wrong.
1) Gasket on lid is excellent should I just coat
821 housing with Permitex blue?
2) Use OLD O rings??
3)Anything necessary on hydraulics after 30+ years
of in-operation, while on motor puller??
4) Things to do to transplant Piston pump and
manifold? (4 new O rings?).
5) pump is pushing fluid on 601 by hand cranking.
do I just fill manifold with fluid before attaching
pump?.
6) Torque specs on lid and pump bolts?
Did I miss anything??
corvetttteguy
11-16-2017 09:33:33
 Re: Transplant hydraulics from 601 to 821 ??? in reply to corvetttteguy, 11-14-2017 09:48:43
I ordered the same gasket kit.
I haven't looked inside yet.
nashranch
11-16-2017 06:24:40
I didn't order the gasket(mine is ok to reuse). I'm hoping the O-rings are in the gasket and o-ring kit I ordered from YT
http://www.yesterdaystractors.com/Ford-600_Hydraulic-Lift-Cover-Repair-Kit_LCRK5564.html
Pump Valve part if needed
http://www.yesterdaystractors.com/Ford-600_Hydraulic-Pump-Valve-Assembly_NCA638C.html
corvetttteguy
11-16-2017 06:07:57
Where did you order the O rings and gasket from?
nashranch
11-15-2017 20:22:37
Yes a light tap with a long block of wood from inside the box. It will fall out the bottom. Of course the bottom plate must off. I took mine today and may replace the orings when my gaskets and o-ring kit comes tomorrow
corvetttteguy
11-15-2017 09:39:54
I see the relief valve is in the 601.
I have removed the bottom plate and I am not
sure if I use a block of wood from above to
push (tap) the protruding valve to fall
out the bottom.
corvetttteguy
11-15-2017 05:52:45
I'll see what comes off of the
donor tractor.
nashranch
11-14-2017 17:58:30
I just removed that plate we're talking about not 20 minutes ago on my 640. I don't remember seeing much in there. Will check again after dinner
JMOR
11-14-2017 11:25:09
yes, I believe it installs from below via that plate.
corvetttteguy
11-14-2017 10:52:59
I know there is a removable plate under the
hydraulics lines outside underneath the reservoir.
Is this where the relief valve is located?
riveroadrat
11-15-2017 04:29:58
 Re: Transplant hydraulics from 601 to 821 ??? in reply to corvetttteguy, 11-14-2017 10:52:59
Parts book says thats Hydraulic pump relief valve. I would get a new OEM gasket for that. Hylomar makes a good sealant. It dries quickly, use sparingly, put on your finger and smear it
JMOR
11-14-2017 10:36:03
Are you sure that isn't top of over pressure relief valve?
