TractorLinks.com
Order Ford 600 Parts Online
Ford 3600 Fuel Sending Unit Question
davidfindley
11-14-2017 08:05:50
Does anyone know if the fuel sending unit is supposed to sit centered in the mounting or offset to the right side?
Deutz Lover
11-14-2017 20:22:47
 Re: Ford 3600 Fuel Sending Unit Question in reply to davidfindley, 11-14-2017 08:05:50
Davidfindley,
Unfortunately your photo has no orientation to indicate where north is on the tractor. Or South towards the driver.
I do see a notch in the side. I will have to look at my 4000 and compare it. I hope they are all the same.
I forgot to ask. What year is your 3600? Is it gas or diesel?
davidfindley
11-14-2017 17:17:29
Thank you for the replies! The sending unit is in but it's not centered in the opening in the top of the tank: https://www.icloud.com/sharedalbum/#B0nGf693ZG6qX72
Is that ok or do I have it inserted into the tank incorrectly?[/url]
Deutz Lover
11-14-2017 09:56:07
If it is like the Ford 4000 there is a notch to align the position of the float. If it is not correct the bayonet fitting won't go in.
markct
11-14-2017 09:46:16
I believe they only go in one way to have the screws line up
RickB
11-14-2017 15:23:52
 Re: Ford 3600 Fuel Sending Unit Question in reply to markct, 11-14-2017 09:46:16
3600 should use a lock ring, not screws. But it is indexed and goes only one way regardless.
markct
11-14-2017 19:58:52
 Re: Ford 3600 Fuel Sending Unit Question in reply to RickB, 11-14-2017 15:23:52
Ok was just assuming it was the same as the older 3 cylinder I had, not sure what my 3910 has I thought it was screws but don't recall, I abandoned the sensor and went simple gauge anyhow!
