1955 Ford 640 Superior Loader and Draft control OP
nashranch
Anybody know where to check the oil level on my Superior loader?
I see fill plugs on it in several spots but not sure how much oil to put in if it needs any at all.
Also the 3 -point doesn't lift high unless I push down on the draft lever. Then it raises up quite a bit higher. Not sure of it's operation...seems weird to push on the draft to raise the arms.
(quoted from post at 18:30:01 11/11/17) Anybody know where to check the oil level on my Superior loader?
and there's no filter of any kind on the loader
A few pics of the model # and fill plugs
I figure a really worn cam follower pin would cause my erractic 3 point operation. Anybody ever weld up that worn area then dress it down so the pin is round again?
(quoted from post at 22:34:58 11/12/17)
I have just pressed the pin out and put in a new one.
If you're really cheap, you could rotate it 180 degrees in the hole
and let it wear on the back side for the next however many years.
I've taken two apart where someone had done exactly that.
Seems kind of silly to me once the cover's off, but there they were.
At least your cam doesn't look to be in bad shape.
(quoted from post at 19:48:31 11/12/17)
Yep Royse... it needs to be replaced. I'm having trouble finding the pin on the YT website. Its a 5/16 x 7/8" pin. I can probably buy one at the local hardware store.
While i'll got that lift cover off waiting for gaskets and o-ringsi decided to flush out the open section there that's exposed. The oil looked good in there but there is sludge on the bottom. Anyway washing it out with diesel. Should be good to go for another 50 years
