I purchased a 1986 Ford 1710 tractor to use around the yard, everything worked fine, it had a loader on it, we removed the loader assembly to work on the tractor, changed all the oils and filters, after doing
so the 3 point would not work, we finely got the air out of that system by cracking the plugs on the 3 point flow control under at the front of the seat, now that works fine. now re-installed the loader
plugged in the hyd. fitting and it would not work at all, tried bleeding the lines and got the bucket to work slow at high RPMs but if you stand in it it will not work at all and life cylinder will not work,
lost can anyone help? any ideas?
