I replaced rear axle seals and brakes. Bearings and race looked good. I added shims until could not move the axles. After finishing I checked the side play by pushing and pulling the tires. There is a small movement, not visible, but I can feel and hear it bump. I am fairly certain it is not the hub and shaft loose.
I think this could be the two axles bumping together but not constantly touching. Should I try to correct this with more shims?
The book tolerance for preload is .002 to .006. How can I get this when thr thinnest shim is .010?
Any suggestions?
Thanks
Cgun
Any suggestions?
Thanks
Cgun
