My tractor took all day to start yesterday (think I'd lost prime because I drained the fuel filter trying to stop the water drain leaking). Eventually got it going by sticking a hot air gun into the air intake, but it's not a very satisfactory solution.
Can someone confirm that the Thermostart plug should be installed in a tapped hole in the inlet manifold? Mine doesn't have a hole but there is a likely looking blank spot that could be drilled & tapped:
If that's not the right place, where else should it go?
