Remote hydraulics question
Lynn Patrick
Will a remote hydraulic valve from a 900 bolt directly onto a 3000? Any specific things to watch for or do?
As usual, thanks for any info!
It will bolt right on, but if you have one like mine and your 3 pt
hitch is in position control mode, when you try to lower the remotes
the handle(s) hit the draft control lever and drops the 3 pt as well.
Thanks guys! Royse, that lever won't bother mine as it is an aftermarket of some kind w/2 handles out the front where you have to kind of step over them. If yours bother you too much, how about a trade?:<)
Mine doesn't bother me at all Lynn, I put it back on my 960.
I put a Tisco dual spool on the 3000 so the handles clear. :)
Now if I could find a couple, more I'd have enough to go around.
LOL not yet. I even have plans to use that single I just got.
I do have a single remote for a Fergy TO35/MF35 that I'm not using.
Might put it on eBay or something. I found a dual for my 35 Deluxe.
Got plenty of singles, every tractor has a remote valve, it would work better for me if a couple more had dual remotes.
6610 has 4 remotes and I have to disconnect half of the loader when using the batwing mower, one line to raise it and a line to raise each wing.
I understand the desire for more outlets. One is better than none tho.
One for a Fergy can be expensive apparently.
[b:ac4fed43f0]This[/b:ac4fed43f0] valve on eBay is just like the one I have except dirtier.
If it sales you know what your's is worth.
Edit: looked through a few pages of his store, some prices look about right, others OMG he's high.
Central Ky? That's where I live!
Now I'll have to find out who that is and where their located.
