860 hyd adjustment
I have 860 that i'm adjusting the 3 pt hydraulics on. I machined a .390 / .450 gauge and have adjusted main control spring, draft adjustment, and position control last. my question is regarding the draft control fork. when looking at the assembly, it is left of lift position rod. the draft control fork has a spring and adjustment nut at the bottom. at present the nut is tight against swivel/bushing. should it be like that, or does it need adjusted as well. I can't seem to find any adjustment info in manual for it. thanks for the help.
