Hey guys!
I wonder if anyone knows where to purchase the following compression springs for the Marvel Schebler small bowl carburetor. The one that goes on the air adjust screw, and the one that goes on the throttle idle screw. The main adjust screw spring is available and can be purchased separately but not the other two I mentioned. I have been all over the internet with no luck. Even if you purchase a kit it only has the main adjust spring and the air adjust spring but not the throttle idle adjust spring. Any advice will be very much appreciated! Thanks!
