(quoted from post at 10:21:31 10/30/17)
(quoted from post at 09:54:28 10/29/17)
https://fluidsinc.net/products/tractor-hydraulic
Here is a $23.50 per 5 gallon fluid that specifically meets the ford spec for the SOS.... And ironically meets the newer spec for new holland....
and http://catalog.parentpetroleum.com/item/castrol-transmission-fluids/castrol-universal-tractor-fluids-utf-/20167
meets the spec...
and..Ford M2C134-A Pennzoil Hydra-tranz
Ford M2C134-B Pennzoil Hydra-tranz
Ford M2C134-C Pennzoil Hydra-tranz
Ford M2C134-D Pennzoil Hydra-tranz
Ford M2C41-A Pennzoil Hydra-tranz
Ford M2C41-B Pennzoil Hydra-tranz
Ford M2C48-B Pennzoil Hydra-tranz
Ford M2C53-A Pennzoil Hydra-tranz
Ford M2C77A Pennzoil Hydra-tranz
Ford M2C86-A Pennzoil Hydra-tranz
Ford M2C86-B Pennzoil Hydra-tranz
Ford M2C86-C Pennzoil Hydra-tranz
This is false as far as I can tell. Nowhere do I see that this product "meets the specs." It claims to be "recommended for use in" numerous applications. In the lubricants realm any wording other than "meets or exceeds" whatever spec one is looking for, is deemed to be other than tested for the spec cited.
The OEM data sheet (
[u:2f96083236]Castrol Product Data Sheet[/u:2f96083236]) uses almost exactly your "meets or exceeds" wording. I'd still take the claim with a large grain of salt as I doubt they have actually conducted all of the prescribed OEM tests - would be really expensive to do so and in some cases the specifications are proprietary and not shared with competitors. Based on the data sheet it appears to be a high quality UTF and I'd expect it to do pretty much what they warrant in the applications they cited. I'd certainly use it in anything I own.
TOH
[b:2f96083236]Warranty and Protection Requirements:[/b:2f96083236]
[i:2f96083236]Meets or exceeds OEM requirements for applications requiring a tractor hydraulic fluid meeting the specifications
listed below:[/i:2f96083236]
[b:2f96083236]OEM Specifications:[/b:2f96083236]
Allis Chalmers Power Fluid 821
Case/New Holland MS-1207/Hy-Tran Plus, MS-1210/TCH, MS-1204/TFD Fluid,MS-1205/TFD-II Fluid,MS-1206/PTF
Fluid, JIC-145,JIC-185, B-6/Hy-Tran, CNH MAT 3505 (MS-1209 Hy-Tran Ultra Fluid), Ambra Mastertrans Fluid CNH
MAT 3525 (M2C-134D), Multi G & Multi G 134, Nexplore Fluid
Caterpillar TO-2
John Deere J20A, J20C, JD303, J14B, J14C
Deutz-Allis AC Power Fluid 821 XL
Ford Tractor M2C53A, M2C53C, M2C21A/B, M2C86B/C, M2C134A/B/C/D, M2C77A
Kubota Universal Transdraulic Fluid, UDT Fluid
Massey Ferguson M-1110, M-1127 A/B, M-1129-A, M-1135, M-1141 (Permatran III)
Oliver/White Q-1766B, UHTF Type 55, Q-1722, 102082, Q-1826
Sperry Vickers Pass on Pump Tests ASTM-D2882 and 35VQ25
Volvo WB-101
ZF 03E, 05F
