BarnabyHooge
Installing this 703 loader has been pretty fun. It's taken just about every tool, trick, and lesson I've learned. That said, I'm just about ready for this thing to work.
I'm now getting foamy hydraulic fluid. Any lift is erratic and the cylinders are soft/bounce. When brought all the way down, it gushes foam from the breather.
It's filled to an appropriate level with new fluid. I understand the cause is likely a leak on the suction side, but I don't see anything. The frame to pump looks really tight, and the return from the controller to the frame looks good as well.
Any tips on finding where the air is getting in?
