BarnabyHooge
Ok, now that I have the 703 loader installed and all my lines plumbed and reservoir filled, the loader isn't working quite like it should. It's really slow regardless of RPM, and both the lift and bucket are jerky. I'm also getting a ton of air and fluid blowing out of the breather if I really extend the lifters up and bring it all the way back down. If I do it slow it seems fine, but if I push the control all the way in as it comes down it really pours out of the breather valve.
Can someone explain what I should be experiencing while purging the system? Roughly how long should it take? I'm guess these items are beyond just air in the system prior to purge.
What should I look for re: air being pulled in? Some of the hoses aren't in great shape. One on the bucket is leaking currently and will be replaced, the others appear to be fine from a leak standpoint. One on the lifter does have some of the metal weave showing, but the local parts guy said that should be ok as long as it's intact.
Thanks All!
Thanks All!
