ford 6700 not moving
Doing chores went to back up and nothing it is a loader tractor mostly moving bales all most 7000 hours put in a clutch along time ago
Is tractor equipped with Dual-power?? Several yrs back my "non-Dual power" 6700 stopped moving when being driven from 1 hay field to another. The trans input shaft stripped out where it joined top shaft in transmission.
Well... if it has dual power, you start by checking the clutch circuit pressures. If not... likely the disc exploded. In that case I'd just go ahead and split it.
Rod
no gears at all and didnt hear any noises clutch out shifts move easly had a clutch 18 years ago when i spilt because of some engine trouble
