Ford 600 hydraulic pump
moday
Can I simply pull this hydraulic pump off with the two bolts to the left near the rear face of engine block? I really just want to clean it and the block....power washed it and still a messy area. I assume a gear drive behind it or something like that but I don't want to risk a good seal if I shouldn't take it off....
Ford 600- think it's a 1957. thanks, moday
I learned about new o rings the hard way. Used old ones,then took things apart and replaced em. Uggggggggggghgh
