Re: 3400 steering leaking out breather in lower attachment
flyfast
New User
Help I had my 3400 spilling fluid out breather in lower column. I tore it apart and seen lower seal was blown so I bought all seals and replaced it all. I put it back together and it works ok. Then went to find center so I could put arms back on and when it hit one side and I held it a second I heard a pop and then same thing was going on again fluid coming out breather in lower housing. Took apart and can see nothing wrong but I know seal is junk from the pop and it is what holds fluid in steering block and out of lower steering gears also I had fluid in upper part of Column also but not much. Now some one replaced lower steering connecter and when I tore steering block apart there was only two plungers with prongs and two balls in one hole is it missing a spring to keep balls apart?? it worked ok at first but I had no arms on it to wheels yet also. Can some one help me figure out why it is blowing that lower seal and pushing fluid into lower box and out breather Thanks Dan
(quoted from post at 14:28:53 10/20/17) I thought I replied to this the other day.
PS,
It's always better to start a new thread
rather than tag onto an old one like this.
Click here
Sorry I am trying to learn it all here. I now see your answer and where to look. I have posted a question again on other thread thanks Dan
