This NAA gets used weekly and runs fine. I took things apart to replace the valve cover gasket and push rod cover gasket on the side. Took off the gas tank and pulled the distributer. All put back together now and it wont start.
? Spark plugs are new (AL437). Fireing order: 1243
? I static timed it with rotor pointed at #1 plug. I'm sure the timing is correct, because a timing light flashes on the 8 degree line while running the starter.
? The flywheel is numbered from 0 to 30 or 40, but there are no numbers on the other side of zero, so all the numbers must BTDC. Right? It's not a matter of confusing the numbers on the flywheel.
? All the plugs show good spark with a spark tester.
? Pulled the gas line from the carb and there is good fuel flow.
The engine doesn't even putt as I run the starter.
Any ideas? Thank you for your help! --peter
